Database has not been repaired - shutdown initiated
EER
Post by EER »
I encouter some problems with the database after the database manager is killed (forced reboot or powerloss).
The project is created using PVSS 3.6-SP2 and has been upgraded to WinCCOA 3.18.
When the data manager is killed and restarted with the
-repair on
argument it fails as shown in the logs:
dbRepair:Copyright (C) 1984-1997, Raima Corporation, All Rights Reserved
WCCILdata    (0), 2021.09.21 10:40:49.884, SYS,  SEVERE,     54, Unexpected state, DataManager, systemCall, C:\Siemens\Automation\WinCC_OA\3.18\bin\dbcheck -a -k -t C:\PVSS_projects\my-example\db\wincc_oa\TypeAndId returned exit code 1
WCCILdata    (0), 2021.09.21 10:40:49.889, SYS,  SEVERE,    106, Database repair, DataManager, repairDBase (on), Database could not be repaired
dbRepair:----------------------------------------------------------------------
dbRepair:Processing key file: sysId.key(12), total of 1 node
dbRepair:------------------------------------------------------------------------
dbRepair:Processing key file: dpId.key(13), total of 64 nodes
dbRepair:Processing key file: confId.key(14), total of 1 node
dbRepair:Processing key file: fixId.key(15), total of 1 node
dbRepair:Processing key file: aliasId.key(16), total of 51 nodes
dbRepair:Processing key file: viewId.key(19), total of 1 node
dbRepair:Processing data file: pvssGlobal.db(0), total of 1 record
dbRepair:Processing data file: objName.db(1), total of 10698 records
dbRepair:Processing data file: objNameTxt.db(2), total of 11984 records
dbRepair:Processing data file: typeId.db(3), total of 357 records
dbRepair:Processing data file: elId.db(4), total of 5707 records
dbRepair:Processing data file: sysId.db(5), total of 2 records
dbRepair:Processing data file: dpId.db(6), total of 1936 records
dbRepair:Processing data file: confId.db(7), total of 24 records
dbRepair:Processing data file: attrId.db(8), total of 519 records
dbRepair:Problems at record 1:
dbRepair:  * set DPATTRIBUTESET(4) error:
dbRepair:    member has null previous-pointer but is not first member
dbRepair:Problems at record 15:
dbRepair:    member has null next-pointer but is not last member
And eventualy:
dbRepair:46 errors were encountered in 46 records/nodes
WCCILdata0:"C:\\PVSS_projects\\TRVL36\\db\\wincc_oa\\TypeAndId"...FAILED (check)
WCCILdata    (0), 2021.09.21 10:40:51.075, SYS,  FATAL,     106, Database repair, DataManager, repairDBase, Database has not been repaired - shutdown initiated
Does anyone have an idea how to fix this. I wanted to try
PVSStoolRepairDb
but this tool seems to be removed from the new WinCCOA release.
Re: Database has not been repaired - shutdown initiated
Please take into account that WinCC OA needs to be stopped properly before shutting down the computer. This needs to be done to ensure that the WinCC OA database and also other parts of the system do not get damaged.
In a plant environment it is recommend to use a UPS.
There is no guarantee that the WinCC OA project can be started if a loss of power occured. Sometimes it can happen that the database is damaged and cannot be repaired anymore.
In such a case you have to install a backup of the database.
Information for the Operating Conditions for WinCC OA you can find in the WinCC OA Documentation:
https://www.winccoa.com/documentation/W ... tions.html
During the renaming of PVSS to WinCC OA all executables have been renamed. Therefore, you cannot find the tool PVSStoolRepairDb anymore. The new name is WCCOAtoolRepairDb.
