I found a bug in the Variable Trend.
Description:
After opening two Variable Trend panels and closing either one, the "Export to CSV" function does not work anymore for the remaining panel.
Version: WinCC OA 3.17 P005
OS: Windows 10
Projekt: GettingStarted_3.17
Steps to reproduce using the GettingStarted_3.17 project.
1. Open aGedi
2. Open "System Management"
3. Open "Reports"
4. Open "Variable Trend"
5. Select any trend from the "Trend configuration" and click on the "View" button. (create a trend with one DPE if necessary). Trend panel opens and can be ignored for now.
6. In the still open "System Management > Reports" panel click again on Variable Trend and open another trend panel (can be the same trend or a different one, see step 5).
7. Close any one of the open trend panels.
8. Click on the "Export to CSV" button on the remaining trend panel.
Result:
1. Panel to select a filename shows a 0 (normally empty) and the following error message appears in the log:
WCCOAui (1), 2020.08.13 16:36:17.725, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
WCCOAui (1), 2020.08.13 16:36:17.725, CTRL, SEVERE, 73, Variable not defined,
Module: Vision_16
Panel: C:\Siemens\Automation\WinCC_OA\3.17\panels\vision\trend\VT_trendsave.pnl [Export data to *.CSV]
Script: Initialize
Line: 3, FileName
Stacktrace:
1: main() at [Module: Vision_16 Panel: vision\trend\VT_trendsave.pnl Script: Initialize]:3
WCCOAui (1), 2020.08.13 16:39:41.276, CTRL, SEVERE, 176, Uncaught exception in thread started at main:
WCCOAui (1), 2020.08.13 16:39:41.276, CTRL, WARNING, 78, Assignment to this expression impossible, VTExporting,
Module: WinCC_OA(1)
Panel: C:\Siemens\Automation\WinCC_OA\3.17\panels\vision\trend\VT_trend.pnl [VT-Trend]
Object: 46 named: "cmd_export" of type: PUSH_BUTTON
Script: Clicked
Line: 86
Stacktrace:
1: main() at [Module: WinCC_OA(1) Panel: vision\trend\VT_trend.pnl Object: cmd_export Script: Clicked]:86
"panels/vision/trend/VT_trend.pnl" contains some removeGlobal statements that affect both open trend panels.
Hope this helps.
