AES Table configuration
Eksergian
Post by Eksergian » Tue Aug 13, 2019 11:06 am
Hello there,
I want my alert table (AEScreen) to be capable of displaying a certain panel when an alert is clicked. The panel will depend of the related datapoint.
To do so, I've noticed that in the "Column Configuration" I could assign an "OnClick" function, such "displayDetail" and "userDefFunc".
I would like to use the "userDefFunc", so I've saved in my project the aesuser.ctl file with the "invokedAESUserFunc", but each time I click on the table, the debug outputs that the column = 0, except for a certain column (acknowledgement) which outputs its actual column.
Do you know why this happens? There could be a previous configuration I do not about, so could something be blocked or protected?
Thank you in advance.
Re: AES Table configuration
Post by leoknipp » Wed Aug 14, 2019 9:08 am
In the AEScreen there is a standard function available to show a panel related to an _alert_hdl config.
Which panel shall be shown you can configure at the _alert_hdl config.
There is no need to implement an own functionality.
