Big advantage of the PVSS Web Client
17 posts • Page 1 of 2
smass
Post by smass »
Did you know about the big advantage of the PVSS Web Client? :
Apart from the fact that it runs in a webbrowser, the panel files, message catalogs and config-files of the server are locally cached at the client and automatically kept up to date!
No need to copy any files manually.
Even if you use a Standard User Interface instead of the WebClient, you can call it with the following option to also use the caching mechanism (you must have the http-server for the PVSS Web Client running on the server side):
PVSS00ui -server
Apart from the caching mechanism another advantage is, that you need no network-share for the files and no open ports for the event- and datamanager in your firewall because the connection is established via port 80.
"Share the fun!"
martijn.goedhart@croonwolterendros.nl
Re: Big advantage of the PVSS Web Client
Post by martijn.goedhart@croonwolterendros.nl »
Dear Sebastian,
It would be good to let people know that a license is needed for the use of the HTTP-connection.
With regards,
Martijn Goedhart
smass
Post by smass »
Thank you for your input Martijn!
You need one webclient license for each webclient you want to use simultaneously
(just similar to the usual UI licensing - you have to use a floating UI license for every UI you want to use at the same time)
For the http-server to which the webclients connect, you need only ONE license on the machine where the control-manager for the http-server is running (not a license for every connection)
jasondonovan
Post by jasondonovan »
Dear Sebastian
I have implemented -server option for all our Clients and Webclients and am impressed.
This saves me implementing other methods to update panels/msg/etc etc. prior to this I had batch files running between servers/clients
Only issue I have with the webclient would be to have a more friendly interface as standard for when the number of licenses used from the 'server' has been exceeded/used.
Operators find this difficult to understand.
I have implemented a script to auto logout webclients after an inactivity delay, only if they operate in a web browser.
Jason
kdroog4pvss
Post by kdroog4pvss »
Sebastian,
On the web client all files of all subprojects and the project are merged into one folder structure. How will this influence the config files, eg. config.level? Will a webclient load all the necessary libraries?
smass
Post by smass »
jason Donovan wrote:
Dear Sebastian
Jason
Thank you for your input Jason, i'll take this into account.
Your script for the auto logout might be a good article for our "Lab" in the Portal - do you want to participate? ;-)
Sebastian
jasondonovan
Yes, no problem.
How shall I send this?
The HTTP Server always merges all config/config.level/config.redu/... files as needed and sends this to the client.
Have a look into the clients /config/config file and you'll find the merged config file with delimiter lines between the
separate files on the server, e.g.:
## /opt/pvss/pvss2_v3.9/config/config.level ##
The merging is done inside the HTTP Server script - you can have a look into the getConfig() function.
smass
Post by smass »
Yes, no problem.
Great!
Zip it and send it to sebastian.massinger@etm.at
Maybe you could add a short discription if you have one..
Thanks in advance!
Sebastian
thalter
Post by thalter »
Does the PC clock on the client and server PC still has to be synchronized?
