getDollarList
AMRPatricio
getDollarList
Post by AMRPatricio »
Hi All,
From a control script, I am trying to obtain the dollar parameters list associated with a specific panel. I tried using getDollarList() and getDollarParamsFromPanel(), however I always receive a error saying "Function not defined". Any idea why?
If a call any of this functions inside and via a panel everything works fine. I guess this means that these functions only be used in panel and do not work when called via control scripts?Any way to solve this?
Thank you.
Antonio Patricio
Re: getDollarList
The functions getDollarList() and getDollarParamsFromPanel() are only working in the UI.
AMRPatricio
Re: getDollarList
kilianvp wrote: Wed Nov 17, 2021 10:56 pm The functions getDollarList() and getDollarParamsFromPanel() are only working in the UI.
Thanks kilianvp. That is what I understood. In my case I need to get such information referring to a panel that is not necessarily running. Any ideas or suggestions?
BR,
Antonio Patricio
Re: getDollarList
In the past, I have often packed the function into a panel and started a UI silent. You can start the UI using system().
Kilian von Pflugk
Re: getDollarList
Post by gschijndel »
There is no need to pack the function in a panel nor to start the UI with the system function.
The UI can be started with a script (but no arguments for the script can be specified) with the '-s' option. The UI might not run without a panel, so also a dummy panel might need to be specified.
To run the UI in the background the '-silentMode' option can be used.
Why do you need dollar parameters list in a control script?
