mobil ui crash
17 posts • Page 2 of 2
Re: mobil ui crash
Not yet. We've ordered the same device as you have and I'm eagerly waiting for it to arrive. Will update if I had a chance to
try with it. (With a Samsung Note 8 I also could not reproduce it)
Re: mobil ui crash
I have now an S8 and installed the latest app from the playstore (3.16 P3).
No crash.
There must be something special on your device.
What I found in your logfile, which I could not see here, is the message "W Qt A11Y : Could not activate platform accessibility." and tons of
messages like "Qt A11Y : AccessibilityNodeInfo"
Is there any special setting regarding "accessibility" you changed/activated on the phone ?
johanningmann
Re: mobil ui crash
Post by johanningmann »
Hi Martin,
I will check and let you know.
Thanks so far for your effort.
Kind regards
Frank Johanningmann
Re: mobil ui crash
ok, further testing shows that I can get the same log messages when I have activated the "text to voice" accessibility feature on the device.
Are you using this ?
johanningmann
Re: mobil ui crash
Hi Mr. Koller,
no do I need to disable it?
Kind regards
Frank Johanningmann
Re: mobil ui crash
If it's not on, then no. But is there anything else in that area which is activated ?
As said, I can not reproduce the problem unless I had activated "text to voice" (which essentially makes the device unusable).
johanningmann
Re: mobil ui crash
Hi Mr. Koller,
I deinstall a Bixby remapper and for now it looks much better.
Thanks for your support.
Kind regards
Frank Johanningmann
