Qt for manager
17 posts • Page 2 of 2
mpoint
Re: Qt for manager
Post by mpoint »
The error message says: "Modules with different CPU types were found" and Kernel32.dll has a red icon with "64" on the right side. Are you running a 64 Bit Windows OS and compiling for 32 Bit? I would guess that there is a 32/64 Bit mixup here.
EDIT:
Also, you mentioned that the issue only occurs when you use Qt, right? I don't see Qt libraries here. (oops, just noticed that the lib.dll is Qt)
CyaNn
Re: Qt for manager
Post by CyaNn »
Yes, I am running on 64 bits windows and I try to compile the lib on 32 bits to be compatible with our server installation.
But I don't know how to force it to use kernel32 in 32bits.
mpoint
Re: Qt for manager
Post by mpoint »
I think Windows should figure that out by itself, with the File System Redirector. Could it be that the NetbeansCtrlExt.dll or the lib.dll is built for 64 bit?
As a last resort, you could try the SysInternals Process Monitor, filter for Operation=Load Image, and then try to load your library again. Maybe it would tell you which library cannot be loaded and with which error code.
Re: Qt for manager
Caron Yann wrote:
I have tries to add all the dependencies dll in the bin folder of the wincc project, but nothing fixed the problem.
It works in the only case I remove my Lib.
The name of my CtrlExt is NetbeansCtrlExt and the qt lib is lib.dll.
If I suppress the call to my Qt lib, it works perfectly.
You should try it with the lib.dll in the same directory as the executable (in most cases this is the PVSS_PATH/bin, not the project bin directory).
CyaNn
Re: Qt for manager
Post by CyaNn »
Well....... okay..... now it's works perfectly....
Thanks a lots....
In my case it is not perfect because of maintenability. I have not any rollback possibility if I patch the PVSS/bin directory.
Is it an elegant maneer to indicate to PVSS to take the dll on the project/bin directory ?
Re: Qt for manager
Caron Yann wrote:
Is it an elegant manner to indicate to PVSS to take the dll on the project/bin directory ?
Include the project/bin directory in your PATH environment variable.
CyaNn
Re: Qt for manager
Post by CyaNn »
Ok thanks you very mutch.
I feared this response ! It does not resolve the rollback capability.
Nevermind, I am happy it's work and now I can develop by test driven developpment. It is the most important at all.
Thank you so mutch
Best regards
Yann
