Ok Alexandre and Leopold,
I figured out that the only way to load dps filter on alert row without flickering is to set it before opening the panel.
Thank you.
Simple AESRow filter changing
- giorgiob
Re: Simple AESRow filter changing
Hello again...
Thinking to this filter changing technique lead me to suspect that all the AESRows of the project, represented by the same properties runtime dp, will be misconfigured after opening a panel with specific AESrow...
Is it true? Is it needed to restore the previous DpList after closing the panel?
- LIGO
Hi Giorgio,
I believe that it shouldn't affect other AESRows in the system (with the same property) if you are altering the cache (it's just a local mapping) and not the datapoint itself. I can remember some tests that RT AES property DP being overwritten by the values of the cache during AES Row init process. But AES Row is doing nothing to AES property DP (the main one, not RT) or its cache.
Leonid Solovev
I wonder why ETM removed our full names from the forum...
Leonid Solovev
- giorgiob
Thank you Leonid.
Regards and Happy new Year.
- tmalone
as we all want to learn from these exchanges. Please post the final working solution.
- giorgiob
By my point of view, the summary of these exchanges is that the code posted at the beginning works properly for setting a dp filter on AesRow, but it must be executed by the navigation panel, before opening the AesRow panel.
Then, because it affects the cache and not the dp itself, I shouldn't worry that other AesRows in other pages are modified.
Regards.
Regards.
