"does not work" is usually not enough to describe a problem.
Please be more specific. What does not work ? Does it crash ? Does it show an error ?
Is this a script you run in a CTRL manager or the UI manager ?
You can store the CtrlScript pointer if you KNOW that it is still valid when you need it.
But keep in mind that the UI manager starts a lot of scripts and that these scripts are also stopped (deleted) e.g. when the panel is closed.
There's something weird here. The param.thread is a null ptr, but since I don't see your code, who knows what's wrong.
Would you mind posting your code here ?
If you'd like to keep it private, just get in contact with our support and send them the source so I'll can have a look.
Can you please give us the number of the service request you have submitted at the Siemens support system. then I can have a look for the current status.
