dpSetTimed() is used often and also drivers are using it when the timestamp given by the PLC is used.
Therefore using a check for _stime is not a guarantee that you get the correct result.
How to know which data point trigger the call back function in dpConnect logic
Re: How to know which data point trigger the call back function in dpConnect logic
- maoyi8212
@Leo @Frenk @Nuno. Thank you for your kindly help.
So now I tried to update my script using dpQueryConnectSingle and I was doing my test like following:
main()
int rc;
anytype userData =getUserName();
rc = dpQueryConnectSingle("workCB", true, userData, "SELECT '_original.._value' FROM 'ExampleDP_SumAlert*.' WHERE _DPT=\\"ExampleDP_Text\\"");
DebugN("After the QueryConnectSingle", rc);
void workCB(anytype userData, dyn_dyn_anytype val)
int i;
DebugN("Callback:",dynlen(val));
for (i = 2; i
main()
int rc;
int i;
for (i = 2; i
- fmulder
Your code seems ok and it should trigger only when the datapoint elements.
Please use the para to look at the datapoints that you monitor. Look at the timestamp of these datapoint elements. They should not change all the time.
I'm pretty sure that a dpQieryConnectSingle() will only fire when the related datapoints actually change.
Good luck
Frenk Mulder
Good luck
Frenk Mulder
- maoyi8212
@Frenk, thanks!
I have checked the the timestamp of these datapoint elements and it actually changes. So the original value means not only the value it self but also the timestamp. right? So maybe I need to check the configuraion of data point itself.
- nmnogueira
Yes, if the timestamp changes, the callback will be triggered. If you are reading the values from a PLC, make sure that the option "Low Level Comparison" is enabled.
- maoyi8212
@Nuno, Thank for for your suggestion. It's due to my wrong configuration of "Low level Comparison"
