you can sign your post with a secrect key and provide the public key (sha1 hmac)
or you use https://jwt.io/
Access to WinCC OA from Webservice via C # API
- kilianvp
Re: Access to WinCC OA from Webservice via C # API
- mhargreaves
Kilian von Pflugk wrote:
Thanks for that - is there a way to sign the post within CONTROL script?you can sign your post with a secrect key and provide the public key (sha1 hmac)
- kilianvp
Mark Hargreaves wrote:
I wrote a similar function already
you can write a function that use openssl and base64.. you use 3.15?Kilian von Pflugk wrote:Thanks for that - is there a way to sign the post within CONTROL script?you can sign your post with a secrect key and provide the public key (sha1 hmac)
- mhargreaves
Yes - I use 3.15
For SHA-1 you could use the 'cryptoHash' function and for base64 you could use the 'base64Encode' function.
Signing your post does not provide any authorization or authentication. It only provides the ability to verify the data against the signature.
But it does not limit anyone from posting data or executing a successful replay attack.
- mhargreaves
How would I sign the post in CONTROL Script?
At the moment I have tried using basic authentication and use:
netGet("https://mark-pc:9443/api/values", result,
makeMapping("headers", makeMapping("Authorization","Basic "+base64Encode("username:password"))));
Your example looks to be correct. What is wrong with it?
- mhargreaves
Gertjan van Schijndel wrote:
I was hoping to do it using something better than basic authentication, but couldn't work out how to do that.Your example looks to be correct. What is wrong with it?
- kilianvp
its wrong! ":" is the seperator. The Server splits the String into 2 Parts. So base64Encode booth Username and Password and concatenate it with ":"
//Edit:
I made a quick nodejs http Server
Your example worked for me:
//Edit:
WCCOAui1:2017.11.30 10:34:18.998[mapping 5 items
WCCOAui1: "headers" : mapping 3 items
WCCOAui1: "Connection" : "keep-alive"
WCCOAui1: "Date" : "Thu, 30 Nov 2017 09:34:18 GMT"
WCCOAui1: "Content-Length" : "14"
WCCOAui1: "httpStatusCode" : 200
WCCOAui1: "content" : "Access granted"
WCCOAui1: "url" : "http://localhost:3000/"
WCCOAui1: "httpStatusText" : "OK"
WCCOAui1:]
It is correct! Yes, the server splits it into 2 part, but after decoding it. For an example of the authorization header, see Wikipedia.
Sorry, I do not have time to make free complete examples for everyone on the portal. Our consultancy department could help you with it.
