Qt custom widgets
20 posts • Page 2 of 2
Re: Qt custom widgets
Yes, it's using openGL. It's based on http://doc.qt.io/QtDataVisualization/
bhavna
Post by bhavna »
OS: Windows 7
WinCCOA 3.11+SP1
I have a similar query. I have attached an image of CRO traces being displayed using some other software. I want to display similar plots in WINCCOA panel. Is it possible using already given widgets or I need to use QT custom widget and make an EWO ?
Bhavna Image
we cannot see the attached image. Maybe the upload failed.
bhavna
Post by bhavna »
I have tried to attached the file(CRO.png) again. But somehow it is not getting displayed in the message. Pls suggest.
Bhavna Image https://www.winccoa.com/fileadmin/image ... es/cro.jpg
amitgolhani
Post by amitgolhani »
Hi Bhavna,
If you are planning to use amplitude and time division plot and planning to display peak-peak and other details similar to CRO then you need to prepare your own CRO widget. You may explore trend widget and check if it can meet your basic CRO requirements.
Best Regards,
Amit Golhani
bhavna
Post by bhavna »
Thank you Amit,
I have already checked for such widget in WINCCOA. I could not find something that could plot 4 arrays (waveform of 400 element each) over a timeline/sample number. These waveforms are read from CRO eevry second over TCP/IP.
I will try EWO with QTcustom plot widget.
Bhavna
Andorhal
Post by Andorhal »
Hello.
There seems to be a problem with the image upload functionality, you can upload the image as file.
You may look at my post here:
bhavna
Post by bhavna »
Thanks. I could upload it as file.
amitgolhani
Can we use SVG based Qt custom widgets to prepare EWO? We are planning to use to SVG for animation, and to control SVG animation we will add controls in widget.
Best Regards,
Amit Golhani
You can of course paint SVG images inside your class::paintEvent(), if that's what you mean.
(e.g. we do this in the DialGauge.ewo. We use QSvgRenderer to render the SVG into a QPixmap and paint the pixmap inside the paintEvent, which is faster than always rendering the SVG in paintEvent())
