PVSS and c#
34 posts • Page 4 of 4
pluns
Re: PVSS and c#
Post by pluns »
Has anyone allready looked at the option of using websockets in .net framework 4.5. ?
Sounds like a similar solution to the one Christian is suggesting.
clicht
Re: PVSS and c#
Post by clicht »
WCF supports websockets: http://msdn.microsoft.com/en-us/library/hh674271.aspx
gSOAP supports "ws" (Using WS-Addressing with SOAP-over-UDP), but I'm not sure if this is the same.
Further gSOAP supports streaming: Streaming MTOM/MIME, which could be used instead.
vogler
Re: PVSS and c#
Post by vogler »
interesting! there are a lot of protocols... the only reason why i implemented my own proxy and xmlrpc over tcp was that i don't wanted to implemented a ctrl-extension - because i am not "fit" in c++ ;-)
peter, where are you from? currently i am in den haag, siemens NL, i am interested in what you already build! maybe you can show me sometime...
pluns
Re: PVSS and c#
Post by pluns »
Andreas,
Check the SCD, I'm stationed in the Hague, building HK2.1 and can show you what we've made.
email: peter.luns@siemens.com
