PVSS and c#
- vogler
Re: PVSS and c#
Hi Marcel, currently i am in the office Siemens Nederland... if you want we can talk about your issue... i will be back on monday.
- mwerksma
Re: PVSS and c#
Hello Andreas,
I work in Zoetermeer and I am very busy with our current project so I don't have time to come to Den Haag, sorry.
I am curious how to create the events in C# so we can create small applications out of PVSS but do use the database.
A while ago I have sent this question to the ETM helpdesk but there they could not fix my problem/question.
If you have time could you contact me please, thank you for your quick response.
Marcel
Marcel
- clicht
Re: PVSS and c#
Hi
Take a look into the xmlrpcHandlerCommon.ctl in the /script/libs directory.
I think there is a functionality implemented, which allows similar to a subscription. This library could be simple integrated in the XML-RPC server. Just call methodHandlerCommon() function.
Remark: A real subscription is not possible over xml-rpc, because it uses http and there connections have a short timeout.
As I remember this functionality uses the "long polling" pattern in combination with a buffer.
Unfortunately there is no client implementation in C# available.
On client side you must start a thread which do cyclic a request of the buffer. If you increase the connection timeout (or is this a setting of the server, I can't remember) than the message overhead is very low.
If something is in the buffer the client get informed and can fire a event or call a delegate.
In this library also a set of other useful functions is implemented.
Hope this helps.
Christian
Hope this helps.
Christian
- mwerksma
Re: PVSS and c#
Christian,
Thank you for your quick response.
I already use the xmlrpcHandlerCommon.ctl and there I see the functions below:
case "pvss.db.startSubscriptionValues":
//int pvss.db.startSubscriptionValues(dyn_string dpes, mapping settings)
methodResult = xmlrpc_pvss_db_startSubscriptionValues(sMethod, asValues);
break;
case "pvss.db.stopSubscriptionValues":
//int pvss.db.stopSubscriptionValues(dyn_int subId)
methodResult = xmlrpc_pvss_db_stopSubscriptionValues(sMethod, asValues);
break;
case "pvss.db.startQuerySubscriptionAlerts":
//int pvss.db.startQuerySubscriptionAlerts(mapping filter, mapping settings)
methodResult = xmlrpc_pvss_db_startQuerySubscriptionAlerts(sMethod, asValues, language);
break;
Cab you tell me how I should use these functions in combination with eachother?
In the comment of the function xmlrpc_pvss_db_startSubscriptionValues this text below is written.
/// calculates a subscriptionId and executes a dpQueryConnectSingle
/// (re-)starts the killConnectionThread for the subscription
break;
break;
break;
- clicht
Re: PVSS and c#
The server uses dpQueryConnectSingle instead of dpConnect.
I think (not sure) you must call on client side (pseudo code):
clientId = pvss.db.getClientSubscriptionId();
subId = pvss.db.startSubscriptionValues(dpes, settings, clientId);
Start Thread and run following in the thread:
while (true)
result = pvss.db.getSubscriptionBuffer( new int[] {subId});
if (result contains something)
//fire event or call callback
//delay 1 second
while (true)
//delay 1 second
- mwerksma
Re: PVSS and c#
Wow,
That was what I was looking for, thank you I will try the code.
Marcel
Marcel
- mwerksma
Re: PVSS and c#
Hello Cristian,
Below is my C#code but I get an error that the parameters are wrong, do you have any idea what I am doing wrong?
In the comment you can see where the error appears and what the error message is.
It is a simple project with a form, a button and a label for error messages
Thank you for your time,
Marcel
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.IO;
using System.Threading;
using CookComputing.XmlRpc;
namespace RPCTest
public partial class Form1 : Form
[XmlRpcUrl("http://localhost/RPC2")]
public interface IStringValues : IXmlRpcProxy
//Declare PVSS functions
[XmlRpcMethod("pvss.db.getClientSubscriptionId")]
Object GetClientSubscriptionId();
[XmlRpcMethod("pvss.db.startSubscriptionValues")]
Object StartSubscriptionValues(string ObjectName, Object[] Settings);
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
Object ClientSubscriptionId = GetClientSubscriptionId_DotNet();
//Subscription ID is 1 @ firtst then 2 and so on, must be ok I think
object[] Settings = new[] { "", "", ClientSubscriptionId.ToString() };
Object dpConnectResult = StartSubscriptionValues_DotNet("test", Settings);
public Object GetClientSubscriptionId_DotNet()
Object res = null;
try
IStringValues s = XmlRpcProxyGen.Create();
res = s.GetClientSubscriptionId();
catch (XmlRpcFaultException fex)
lblError.Text = fex.FaultString;
catch (Exception ex)
lblError.Text = ex.Message;
return res;
public Object StartSubscriptionValues_DotNet(string ObjectName, Object[] Settings)
Object res = null;
try
res = s.StartSubscriptionValues(ObjectName, Settings);
//Here I get the error:
// PVSS00ui (1), 2012.12.13 20:22:07.817, SYS, SEVERE, 51, Parameter incorrect, Error parsing xml-rpc stream, Method: pvss.db.startSubscriptionValues,
return res;
Marcel
using System;
using System.Data;
using System.Text;
using System.IO;
namespace RPCTest
public Form1()
Object res = null;
try
return res;
Object res = null;
try
return res;
- clicht
Re: PVSS and c#
Hi
Take a look at the Server-Log-File. There should be further information.
Maybe the object[] settings is the problem.
Therefor is nothing implemented on the server and should be empty.
I think this would work if you transfer an empty KeyValuePair or hashtable. If this is not working define a empty class or struct.
Further I think you defined the methods wrong:
uint GetClientSubscriptionId();
uint StartSubscriptionValues(string[] ObjectName, KeyValuePair Settings, uint clientId);
Remark: If you implement the XML-RPC server right the fault/error return values are transferd to XML-RPC errors and result into a exception on client side. This means you could define the XML-RPC methods typesave with the real types.
The "mixed" return values are workarounds on serverside, because exceptions was not available as the library was written.
A good example for a correct XML-RPC server is available in the AddOn "Etool" of the WinCC OA installation.
There is also a workaround for a bug in the XML-RPC server implemented:
sTmp = content;
if (getType(sTmp) == STRING_VAR)
strreplace(sTmp, " />", "/>");
strreplace(sTmp, "", "");
Christian
sTmp = content;
Christian
- vogler
Re: PVSS and c#
have seen christian already gave you all needed information
if you are interested, some time ago i created a basic C# library - i played with C# + XMLRPC + WinCC OA to create iPhone and Android mobile applications with MonoTouch (www.xamarin.com - pretty cool product)
I have now uploaded the source to sourceforge:
http://sourceforge.net/projects/roc-xmlrpc/
http://sourceforge.net/projects/roc-winccoa-lib/
I also played with dpConnect: http://www.youtube.com/watch?v=_QKoItKdkks
I think i created a tcp connection to have a state-full connection and sent the XMLRPC over that tcp connection...
Or your client can also act as a XMLRPC server and OA can send xmlrpc-calls to the C# XMLRPC-Server - but of course then you will have problems if you have NAT or a firewall between client and server.
Andy
Andy
- mwerksma
Re: PVSS and c#
Hi Andy,
Indeed I got feedback from Christian and also of a collegue of mine but I do nut fully understand
the code and how to use it. Now I have donwloade both your projects and put them in a solution
and I am now able to rebuild without errors but I haven't figured out how to omplement this code
in a C# Windows Form project.
Do you have sample code of a Windows form project?
What I want to create is a simple test form where values can be shown and altered with the use of events.
I understand that is possible with this code but how?
Marcel
Marcel
