Default user?
- n_lev
Re: Default user?
Fair enough. Thanks for your help, guys. I implemented what I needed by dpConnect'ing to the username and re-logging in into "guest" once the username changes to "".
- jimtaylor
Re: Default user?
Sorry to open up an old thread but this is exactly the functionality we want to implement.
Can anyone please tell me what function to use to re-login as guest? I have tried setUserId(4096) [and variations like setUserId(getUserId("guest") or setUserId(4096, "")] but this does not seem to work.
Many thanks.
Jim
Many thanks.
Jim
- n_lev
Re: Default user?
I did something like this:
That should get you started
main()
string dp;
dp = myUiDpName() + ".UserName:_original.._value";
dpConnect("changeUser", dp);
changeUser (string dpUser, string user)
// If username changed to ""
// login as "guest"
// When logging in from one user to another
// the system actually changes Ui.UserName to "" first
// before changing it to a new user name
// hence the use of "getUserName()" function
// so we can ignore that first change to the Ui.UserName
if(user == "" && getUserName() == "")
setUserId(getUserId("guest"),"");
dpSet(dpUser,"guest");
