The new C# API
13 posts • Page 2 of 2
wenjie.meng
Re: The new C# API
Post by wenjie.meng »
I follow the new api document build my first console app on Linux (Oracle Linux 9), I got a error message when just run this statement :IOaManager myManager = OaSdk.CreateManager();
Exception has occurred: CLR/System.TypeInitializationException
An unhandled exception of type 'System.TypeInitializationException' occurred in ETM.WCCOA.Interop.dll: 'The type initializer for 'ETM.WCCOA.Internal.CSharpBridgePINVOKE' threw an exception.'
 Inner exceptions found, see $exception in variables window for more details.
 Innermost exception 	 System.DllNotFoundException : Unable to load shared library 'CsCoreBridgeV319' or one of its dependencies. In order to help diagnose loading problems, consider setting the LD_DEBUG environment variable: libCsCoreBridgeV319: cannot open shared object file: No such file or directory
   at ETM.WCCOA.Internal.CSharpBridgePINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_CSharpBridge(ExceptionDelegate applicationDelegate, ExceptionDelegate arithmeticDelegate, ExceptionDelegate divideByZeroDelegate, ExceptionDelegate indexOutOfRangeDelegate, ExceptionDelegate invalidCastDelegate, ExceptionDelegate invalidOperationDelegate, ExceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate, ExceptionDelegate outOfMemoryDelegate, ExceptionDelegate overflowDelegate, ExceptionDelegate systemExceptionDelegate)
   at ETM.WCCOA.Internal.CSharpBridgePINVOKE.SWIGExceptionHelper..cctor()
some one can help me? thank you.
Re: The new C# API
You need to set LD_LIBRARY_PATH env
export WINCCOA_HOME=/opt/WinCC_OA/3.19
export PATH=$PATH:$WINCCOA_HOME/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$WINCCOA_HOME/bin
If you start the Manager from WinCC OA Console LD_LIBRARY_PATH env is already set.
wenjie.meng
Re: The new C# API
Thank you @kilianvp
